Originally Posted by Smallblock454
Hello Gothaur,
On the right front side there is also the brake booster. If you open the frunk you should hear if it's coming from there. Intermittent interval could maybe be caused by the ABS system checking pressure. But in general this should lead to a warn signal.
Did you put the car on a diagnosis system and check it for error codes?
Regards, Markus
Thanks Markus: next time I hear it, I will follow your suggestions.
No, not recently at least, but I will in 10-15 days.
Cheers!
