Old 05-02-2016, 01:07 PM   #2
Ben006
Ben-Auto-Design
Ben006's Avatar
When I got those two exact codes it was because the hose from TB to AOS was not seated correctly on the TB side. Car always ran perfect with that condition. Once I reset the hose, no more codes.
They are codes that tend to point to a Vacuum leak.
Are you seeing any other symptoms, Smoke, High vacuum(oil filer cap hard to remove)? Can you hear any sore of vacuum leak
I'll check everything else tomorrow in the shop at school
The PCV hose is "new" but could very well be the problem.
Could very well be the case. The OEM AOS units have an inordinate level of failures, some literally right out of the box, so I would not be at all surprised to see an aftermarket unit crap out quickly.
Yes that's what I thought...
Before I replace it, the "old one" was a 18month old!But I don't think it was OEM either.
Thanks guys!
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
