When I got those two exact codes it was because the hose from TB to AOS was not seated correctly on the TB side. Car always ran perfect with that condition. Once I reset the hose, no more codes.
They are codes that tend to point to a Vacuum leak.
Are you seeing any other symptoms, Smoke, High vacuum(oil filer cap hard to remove)? Can you hear any sore of vacuum leak
Seal Grey
