What tires are you running? -3.2 is allot of - Chamber for on street tires. Your stance is pretty low from your picture. Are you bottoming out your struts?
I'm running same struts at the max setting and -2.5 in the front on tight tracks -1.5 front on fast tracks -2 rear 0 toe. 15 mm wheel spacers front 7 mm wheel spacer rear. 4" clearance from the body weld behind the front tire to the ground. 4.25" to the rear braces to the ground at the front edge of the inner rear wheel well. GT3 arm front and rear no spacers front, 6mm spacer rear. 235 40 18 front 275 35 18 rear
On RS3 tires I get push front. I can improve a little by adjusting rear toe link out 1 to 2 flats. (Negative rear toe) On Z214 the car is pretty neutral. On NT01 the car is a little loose in the rear if I accelerate to hard in the middle, and I have to play with the pedal until past the apex.
