Old 05-01-2016, 08:33 AM   #17
steved0x
steved0x's Avatar
I have aftermarket toe arms that provide extra adjustment range.
The back steps out during steady state cornering with maintenance throttle. Very scary.
Braking is good, turn in is excellent, I just have no confidence in the back and it is affecting me mentally.
The heights I ended up with were just what I came up with using the ksport starting points. It looked ok by the fender heights the back is 30'ish mm higher which is more than an inch, I didn't realize that they were that far apart.
I softened the back 6 clicks and hardened the front by 6 clicks so the fronts are 12 clicks from full hard, and fronts 12 clicks from full soft, with 12 clicks between them. Seemed to help but by this time my confidence was shot, so I called it a day and we are heading home...
