Old 04-24-2016, 10:35 AM   #7
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Hodan View Post
Ok thanks guys but u don't tell me why?
When you do an oil change, do you take the old oil from one car and put it into another? If your brake pads are worn, do you go to a junk yard for 15 year old, used brake pads? The coolant expansion tank is worn by both use and age. The plastic deteriorates over the years. Heat and the cycles of expansion and contraction break down the structure. A used tank from a 1999 will not last nearly as long as a new tank. It is near the end of it's designed life-span.
....why am I even bothering to type this.
78F350 is online now   Reply With Quote
