Old 04-23-2016, 03:09 PM   #6
steved0x
steved0x's Avatar
I just finished my last rear bearing today. Here is my trick for the ebrake. After you pull the hub and pull and reinstall the bearing, put the ebrake shoes back on first before putting the bearing retainer plate and the hub. *Much* easier the two springs that hold the brake shoes flat, peek over the top and behind the wheel carrier and make sure the spring has hooked properly around the back. If it pops off bad things will happen.
