Old 04-17-2016, 10:45 AM   #2
Gelbster
It is all in Search.
Short version : yes you can press out the bearing from the pulley with the correc equipment and replace with generic.
The pulley will probably crack unless you are an expert.
Suggest you check Rock Auto for the complete pulley+ bearing to avoid issues and get a new Gates belt while you are there ?
Be very careful checking the alignment of the pullies. Use a steel straightedge across the face of all adjacent faces. If they are misaligned - eve slightly ,you'll have issues....
