Old 04-15-2016, 09:35 AM   #17
steved0x
steved0x's Avatar
Front bearing:
Pulling hub - good, same as backs
Pressing hub - good, same as backs
Pulling bearing - have to use the same plate as pressing the hub, fits the inner race, we'll see
Pressing bearing - press plate overhangs the bearing, but since it mounts flush to wheel carrier should be ok
Since base boxster uses the same bearing all 4 corners and it is the same as the S front bearing, it would suck if this tool is missing the smaller plate to make it work. I'll know this weekend.
Good luck on the caliper rebuild, are you going with high temp silicon dust boots?
