Window Problem
I recently discovered a new problem with my driver side window; The window would drop 1/4" and immediately raised back up after I open the door. Normally it would drop and raise only after the door is shut. I also notice that the window would stay at its 1/4" drop position when I hold the door open. Passenger side window is fine. Both windows would go down as normal when the top lever is released. Both windows operate fine up and down. Any ideas on what can be causing this?
