Old 04-14-2016, 01:42 PM   #21
steved0x
steved0x's Avatar
Lap1
If you choose the Accusump electric valve instead of the mechanical handle, would the cylinder be re-charging by itself when the engine is running, and release the oil when you open the switch? Do you know if this would be a reliable option for a daily driver? just curious..
Thank you in advance
I'm not him, but if you choose the EPC valve the operation of it is like this:
When the valve is off, oil can still flow into the accusump but not out. I believe it flows in faster or slower depending on if you are above or below the target pressure, but I'm not sure which.
When your oil pressure drops below the target threshold for the switch, the valve automatically opens up and lets oil out of the accusump in order to restore oil pressure back to the system.
One use case would be like this:
  1. Turn the key to on, and then flip the switch to enable the pressure sensing switch of the accusump.
  2. The pressure switch would be below the threshold, so it would open the valve and oil from the accusump would flow and pressurize the system, to provide some oil pressure and prevent a dry start
  3. Once you crank the car, oil pressure would quickly rise to above the threshold (if the car is cold) and oil would go into the accusump, stored at the current oil pressure of the car.
  4. If you leave the switch enabled, and then go driving, anytime the pressure falls below the threshold (our cars typically use the 35-40 switch), the valve opens and oil flows out to restore pressure
  5. Once the oil heats up, if you are driving around town, you will be below the threshold everytime you go to idle, and possibly even during low rev driving. It is not really needed in this case. But if you were on the track zipping along, you would want this behavior when you hit a long sweeper at high G and oil pressure starts to drop.
  6. When you get done driving, rev up the engine to around 3000 or so for a moment (if you have an oil pressure gauge, rev up to your desired pressure and hold for a moment) and then turn off the switch that enable the electronic valve, and then shut the car off, thus storing pressurized oil for the next start
