					Originally Posted by jdraupp  Does his tool make it easier than it would be with the sir tool? |
It would be roughly the same as the SIR tool with one major difference - the SIR tool can pull the hub, the Arnnworx tool cannot pull the hub, you would have to find a way to do that, such as a slide hammer or using bolts threaded through the hub to press on the wheel carrier and push the hub back out.
