Old 04-03-2016, 07:57 PM   #10
Gelbster
Just do a pressure test? 18 lbs for 30 minutes on the tank and the same on the cap. First with a cold engine then hot.
Be careful with the replacement tank if needed. Lots of bad ones.
Don't dismiss the possibility that the w/p is beginning to leak?
Good luck and let us know how it is resolved. I hope you have an uneventful journey home after the repair.
If the leak is minor, you might ask others of they have had any experience of limping home with the pressure relieved by not screwing the cap on tight + frequent top-ups? I'm not recommending it because I have never tried this on this engine.
