Old 03-24-2016, 06:08 AM   #2
liquidimports84
Originally Posted by CrisZenithBlue View Post
sounds like slack in the regulator cables. when you use the handle it drops just a bit to clear the seal, when you put the top down it drops a few inches so that would explain the symptoms.
but the bottom line is, if you push down on the window and it goes down a bit, that indicates slack in the cable.
lookup the 5$ bike cable fix on the forum or get a new regulator for around 150$. Dont buy used, it's a bit of a pain to replace it if it breaks again.
When I use the handles it does not drop down at all, just when I put the top down, do you think regulator is still a problem?
I did find a regulator for $54,
http://www.ebay.com/itm/New-Passengers-Front-Power-Window-Lift-Regulator-Porsche-911-Boxster-Aftermarket-/391412377784?fits=Year%3A2001%7CMake%3APorsche%7CM odel%3ABoxster&hash=item5b21fee8b8:goQAAOSwoudW8Wdw&vxp=mtr
liquidimports84 is offline   Reply With Quote
