Old 03-15-2016, 03:12 PM   #18
Gelbster
Interesting issue. Pedro has discussed it re. Sebring Turn 17. Ask him ? He removed his Accusump and used a system similar to yours(he calls it Technosump).
With your LN 2 qt. deep sump + EBS baffle kit + correct oil level + correct grade(??) of oil- there should be no substantial drop in oil pressure due to the pick up being above the oil surface in the sump at your g-force.
It does seem like the issue is windage/baffling not foaming ?
Are you sure the EBS kit was correctly installed ?
Extended pick up tube would be the #1 question.
#2 would be the horizontal baffle
#3 the baffle flaps are closing correctly ?
Foaming would exacerbate an incorrectly functioning baffle/unmodified oil pick-up.
Drop the sump and inspect?
