Old 03-14-2016, 08:36 AM   #2
Porsche9
Porsche9's Avatar
If it is from the pedal area, it is likely the clutch booster spring.
I had a squeek for a while from mine and then it stopped when the spring broke.
Replaced the spring (thanks Woody) and all is good
In my case, the squeaking was a sign the spring was breaking.
Its a pretty easy DIY. Do a search here and on rennlist and there are a couple of threads on the spring
Thanks JayG. Mine definitely sounds like it's in the pedal area. I'll check it out.
Now I have two projects, this and the window regulator (the common issue with the window not dropping when you open the door).
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
