Old 03-12-2016, 04:50 AM   #14
jsceash
jsceash's Avatar
It might be possible to fix with out pulling the engine. The problem will be you need 3 special tools. It can't be done with out them. The procedure can't be found in the in the 99-04 manual, 101 project, or the Bentley manual. PM me with a email address, I can email the chapter PDF from the 2005- 2008 shop guide.
You need to read the manual very carefully and don't cut any corners. You may have to remove the cross member behind the motor bottom covers and header to have enough room.
You can probably find the tools on Ebay
Porsche 997 Engine Timing Tool Set Crankshaft Locking Tool Kit | eBay
You also need a torque wrench and a angle guide either hand made or also purchased on Ebay.
