Old 03-10-2016, 11:35 AM   #1
JFP in PA
Originally Posted by spendy View Post
If I am understanding you correctly, you don't need to repair the crank, so whatever a crank repair sleeve is that isn't what is needed.
I would use a bit of sealant to fill whatever gap is created by the scratch in the case.
Regardless of the reason, if you are using the updated PTFE seal, never use any type of sealants. One of the quickest ways to get one of these to leak is to use sealants.
Crank sleeves are used when a seal has worn a grove into the crank itself, making it impossible for the seal to work. They are at best a stop gap measure, and will not address your problem.
