Old 03-02-2016, 10:09 AM   #2
steved0x
steved0x's Avatar
I haven't, I have used the Motive bleeder with success. The clutch slave cylinder is in a very tight spot too... not sure if there is room for a little pump like that. And it looks like it would be easy to run that little can dry. When you are under there and finally get a good connection to the slave cylinder bleed screw, you will want to do it in one shot At least for me It was TIGHT under there
