Old 03-02-2016, 09:27 AM   #4
steved0x
steved0x's Avatar
In the video the cables were moving underneath in conjunction with the shift lever moving. I would consider it play if you could move the shift lever with no corresponding movement in the cable ends underneath. Probably normal. Was your transmission cold or warmed up from driving when you made the video? If cold I would be surprised to see wiggling like that, but with it warmed up, I would not be surprised.
I can check mine cold this evening, I have that same shifter in there now.
