Old 02-27-2016, 04:39 PM   #1
jsceash
jsceash's Avatar
P0410/1411 Bank 1 & 2 below limit
Possible fault cause
♦ Secondary air injection pump is not triggered
♦ Secondary air injection pump does not work
♦ Air supply lines restricted
♦ Electric change-over valve does not function
♦ Air change-over valve does not function
♦ Vacuum system leaking
Start by looking for a vacuum leak. Any of the small tube off. The large hose from change over valve to pump cracked or off. Bad change over valve (This is under the passenger side intake).
