986 door faults
i have a 1998 boxter 2.5 i have a fault the both doors lock and wont re open i have to use the key turned to the right to lower window then reach inside to open door pull also the center console switch when operated several times will fail in the locked position i have to open the door handle to reset
anyone knows where to go next car central locking seams ok but locks both doors closed
Reason: adding info
