Before you reflash , suggest you ensure it will pass SMOG . The new machines here in California are getting smarter at detecting non-OEM ECU programming. It would be a very expensive mistake if you got tagged for "Tampering ". Pity because it is a great mod. -particularly if you also eliminate the troublesome SAI (search). But that also has the same risk and at resale.
