A pop then you fell huh? Well, a few questions:
1) Did it hurt after the pop or was there any pain preceding it?
2) Any warmth or point tenderness following the fall?
3) Were you able to walk at all within the next hour or so after falling / are you able to bear touch toe weight with the crutches?
4) Are you currently feeling any laxity in the joint?
Your description as of now sounds like a possible tear of the ACL or PCL... I'd have either a sports doc or orthopaedic doc take a look at the knee. Best test is an MRI because it helps us see the soft tissue much better than xray and CT.
I've come to search for and taken so much advice from this forum for my car I figured this is my chance to give a little back hahah!
