Old 02-05-2016, 08:02 AM   #2
steved0x
steved0x's Avatar
I had a bad CPS, it failed when I was driving down to Sebring. The car would just shut off and wouldn't crank. After sitting for a little bit, it would crank but then shut off a little later. It did this 4 or 5 times, but the check engine line didn't come on until the next day.
When you attempt to crank the car, do you see any activity on the tachometer? My understanding is that it gets the RPM from the CPS and if that is bad, you will/may not get any RPM on the tach.
