Old 02-04-2016, 08:03 AM   #18
steved0x
steved0x's Avatar
Just had an alignment done
Toe was off on the front
Now have 0.03 total toe front and 0.10 rear
also camber went from -.9 LF -.4 to -.9/-.7 (maxed out)
I had them check the components for wear and they said all was good
Still have a vibration starting at 80 MPH. Gonna have the balance checked
Also still have a drift to the right, Castor is 8.0 LF and 7.6 rt. Looks like the only way to fix that is the Wishbone Adjustable With Eccentric Screw and it is ~$450 rather than $100
Check Elephant Suspension, they sell some replacement bushings that can help you get those into adjustment, if it turns out that is what you need to do.
Elephant Racing | Wishbone Caster Adjuster | Porsche Boxster/Cayman
