I want to say the oil filler tube is three sections. So you should be able to disconnect them all and have three separate pieces. Since you're going through this it may not be a bad idea to replace them all anyway. They are relatively cheap and they often get brittle and crack from age. They then cause vacuum leaks. Maybe someone who has dealt with an engine drop can verify.
