			I installed a 4 bow 03 top on my 01 this weekend and it was a simple install. It only took a few ~3 hours to remove the old one and install the new one.
 Most of the time was wasted fiddling with the trim panels, that I had to remove and reinstall more than once because I did not check to make sure the Headliner tension strap was attached prior to the frame install.
 I was wondering what the loose extra strap is for on the drivers side that attaches near the ball link on the 03 top?
 I also have a bit of looseness in the fabric at the sides of the window and I'm thinking that the 4th bow needs to be adjusted to take up the slack.
 Also wondering if there is an adjustment for the wire that tensions the top along the rear part of the frame where it goes around the window as its pulled away from the frame a bit and needs to be tightened I think.
				"It broke because it wants to be Upgraded   "
Short Shifter, Touch Screen Dual Din Radio, 03 4 Bow glass Top  (DD & Auto-X since May 17,2012)
