Little things to do that I think have been great....
LED interior lighting...Under $15 using online sources such as _bay and Amazing.
Audio:
If you have the factory radio and want to keep it. Look for and Auxiliary input kit.
New dash speakers....At least remove yours and check the foam surrounds. Mine were toast.
Door/rear speakers. A little less bang for the buck but still worth considering.
Wind blocker....If your car didn't come with the mesh and Plexiglas wind blocker, get them! Thy'll extend your top down experience by about 10 degrees at least.
Also, Check all your convertible drains and lube the pivot points and tracks of the top mechanism...not an upgrade but it'll save you potential trouble down the road. What this will do is familiarize you with putting your top in service position and seeing where everything is around your car!
