Old 06-05-2006, 08:16 PM   #4
kyle986driver
Originally Posted by xclusivecar
What does pushing in the clutch have to do with the handbrake? I've owned manual transmission cars for years and have never been told/had to push in the clutch before pulling up the brake.
if you pull the handbreak with the clutch engaged (and car moving at a speed) then you still have the full engines power working against the rear wheel brakes(the handbrake). I pull the HB all the time to make quick turns and with the clutch engaged i hear the loud POP and the car hardly slows down.
xclusivecar- what are you trying to do when you pull the handbrake? lock up the back tires or just curious as to what will happen?
kyle986driver is offline   Reply With Quote
