Old 01-10-2016, 05:05 PM   #702
jb92563
jb92563's Avatar
Originally Posted by flouese View Post
Looking for the MAF security torxs. Have any? Any thoughts on how to remove the two I striped?
Dremel a straight cut on the screw heads so you can use a flat screw driver to remove them. Replace with something else after.
Go slowly with the Dremel so as not to build up too much heat to avoid melting the plastic. Perhaps you can squirt with water as you Dremel the screws to keep them cool.
