			I had a second problem due to the amount of HP to the axles. I sheared axle bolts regularly. The 2003 axle had 10.1mm through holes but used a 8mm thread shoulder bolt. Answer seems that the 2005 and 2006 5 speed use a larger  bolt and they still bolt up to the 2003 axles. Currently I run a 2005 5-speed with 10mm axle bolt (This has a slightly higher final drive)
				__________________2003 Black 986. modified for Advanced level HPDE and open track days.
