Old 01-02-2016, 08:57 PM   #431
thstone
I tried to take my wiper fluid reservoir out once and could never get it out (I was trying to route a new hood cable). Now my fluid won't spray, I think something got loosened (pump maybe?) and I need to get under there and fix it. Besides the one bolt, did you recall doing anything special or tricky to remove it?
There is just the one bolt. The rear of the reservoir is held in by two rubber plugs that fit into a bracket. Once the bolt is removed, just pull/yank the reservoir directly out from the bottom and the rubber plugs will pull out of the bracket. You have to give it a good hard pull and if you didn't know that it was just a rubber plug was holding it in, you'd be convinced that you'd break something - but you won't.
I'll post a picture tomorrow.
