Old 01-02-2016, 06:42 AM   #2
jsceash
jsceash's Avatar
1. Your IMS bearing & shaft an early sign, later chain rattle, timing issues, then varying levels of failure.
2. The timing chains and sprockets, Chain rattle, timing issues, then varying levels of failure.
3. Valve Tappets & cam shafts, Valve clatter, then scavenge pump or valve failure and varying levels of of other failures.
4. The crank, piston slap, rod knock, and worse.
