Old 12-31-2015, 12:58 PM   #1
roocox@gmail.com
roocox@gmail.com's Avatar
Black Spec Boxster Build
Spec Boxster Build, the beginning of about a two year projected timeline. I don't have clearance to race until our youngest (3 month old) is at least two. And that gives me a comfortable timeline, around work and family life.
Donor: 1998 with 107,000 miles
Replace bearings in Upper, Lower, and Tensioner pulleys with 6203 bearings.
Using the outer race from an old bearing, cut with a dremel cutoff wheel, all the way through. This will allow the old race to be used for pushing in the new bearing and allow for easy removal of the old race from the pulley housing.
Using a vise as a bearing press.
roocox@gmail.com is offline   Reply With Quote
