Old 12-26-2015, 11:47 AM   #14
Gelbster
Beware using generic worm-drive hose clamps to replace the OEM clamps.
The original constant tension spring-band type clamps are much less likely to allow seepage over time. But cheap chinese clamps may have incorrect temper
If the 'ears' of the spring-band type clamp are oriented in a position that is difficult to access ,you can push it round the hose with a screwdriver or pull with a hook. A worm drive clamp can be much more difficult.
https://www.rotorclip.com/hose_clamp_tech_data.php
