Old 12-26-2015, 07:55 AM   #1
Crib
Crib
I want the USB connector for the Carplay to be in the remaining storage compartment so next task is to fit the female connector into that.
I mark the spot and drill holes around the edges...
...and cut it clean with a sharp knife. (The famous swedish Mora Knife )
Adding a corresponding hole in the rubber insert.
Pressing the female part into the whole, snug fit.
Fixating the connector with a major load of glue from the glue gun. Better safe than sorry, dont want this to losen up while connecting/disconnecting cables.
Treading the USB cable trough the hole into the back of the center console.
Pressing the storage compartment back into place. Found a 10cm (3 inch) black iphone cable that will be perfect in there (and also hide the whiteness of the connector).
Crib is offline   Reply With Quote
