Thread: P0440
Old 12-20-2015, 07:41 AM   #1
thstone
Originally Posted by jeeper31 View Post
Is it bad to drive the car with this code?
The code indicates a problem in the venting system of the fuel tank vapor recovery system.
If the fix isn't as simple as replacing the fuel cap, then there is a diagnostic process to determine exactly which component has failed.
This failure should not affect the drivability of the car and should not pose much risk of causing further damage. The car should be ok to drive until you can get it repaired.
