Hello guys.
in the middle of replacing rear wheel bearings on 01S.
using the sir tool to remove the hub, the hub came out with the inner race of the bearing still attached to it.
not sure if i did something wrong, or the bearing was so bad that it fall apart.
anyway, i'm on my way now to the local autozone or HF to look for a puller that might help. i noticed two grooves on the hub so i assume some sort of a puller will fit in there.
if you got any ideas how to remove it, it will be appreciated.
thanks in advance.
Meir.
