Thread: Smoke bomb
Old 12-16-2015, 08:44 AM   #26
Gelbster
While you are in there....
1.Clean the coils very carefully so you can inspect for cracks. You will need perfectly clean coils to see any hairline cracks .A lens and bright light helps. If the cracks are small and water hasn't yet got in , you can seal the cracks with a smear of epoxy.
The generic coil packs are $30.Beru is double- unless you buy at Pelican.
2.Check the spark plug tubes for brittleness (& oil leakage :-)) $6 ea at Pelican
