			I did my own PPI on a 2001 S and missed a couple things like Wiper Sprayer disconnected, electric seat recline did not work, but I went over the meticulous maintenance records and you can tell the car was well maintained so I took a gamble.
The fixes to my missed items were a couple dollars so I got lucky.
Also, if there is even a single drip of oil anywhere coming off the car then you should get a professional PPI as there is some issue lurking like RMS bearing, IMS, AOS, sparkplug tubes etc.
A great condition Boxster does not leak anything at all, anywhere. If it does then move on as there are plenty to choose from that do not leak.
At $8,500 its a decent deal, even considering you will spend $3000 replacing the clutch and rms bearing in the next couple years.
Boxster Maintenance is best budgeted at $2000/yr. Much less if you do it yourself of course, and its surprisingly easy to work on despite the mid engine location.
				"It broke because it wants to be Upgraded   "
Short Shifter, Touch Screen Dual Din Radio, 03 4 Bow glass Top  (DD & Auto-X since May 17,2012)
