Old 11-23-2015, 11:59 AM   #1
jpl2407
Can the doors be adjusted???
My drivers side door does not like to close without a firm push or pull (depending if you are getting in or out of the car). On closer inspection it looks like the door is slightly too high for the locking mechanism to be centered, and, it is catching (see pics)
I noticed on the striker plate (pic below) there appears to be lines that may, or may not be there for alignment purposes:
Can this alignment be adjusted to make the door close as it is supposed to without catching, or is it something more complicated than that?
Regards,
Jake.
jpl2407 is offline   Reply With Quote
