Old 11-13-2015, 07:27 PM   #10
TrumpyAl
The only thing wrong with it was a wet immobilizer. I threw another ECU/immobilizer in it and it started right up.
Hopefully you won't consider it rude to try and leech off your knowledge in your build thread?
If it turns out that I have a dead immobiliser module under the seat (it looked fine to me but I did notice the carpet is wet on the underside), I was under the impression that you needed to change the ignition, immobiliser and DMU as a set. Is that right?
I ask as it sounds like you didn't change the ignition?
Also, mine is a Tiptronic S, but it has a %]#{¥ 2.7 in it - so if I'm buying a set, to avoid costly reprogramming by Porsche I'd buy a set for a matching model year 2.7 Tiptronic, is that right?
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
