Old 11-08-2015, 10:52 AM   #144
Gelbster
Sometimes the best(?) answer is to just follow what has worked best for others .
No need for DOF + Hybrid ceramic bearing. Splash is sufficient. If you wanted to experiment, you could buy a DOF kit and substitute a hybrid ceramic bearing for the generic steel bearing usually included.The generic bearing is only worth $5.
Nobody sells a full ceramic IMSB?
TechnoFix DOF - Solves the IMS issue in 1997 - 2008 Porsches
Is this what you mean? check size.
http://www.amazon.com/6204-2RS-Bearing-Hybrid-Ceramic-20x47x14/dp/B002BBEYNU
A bigger challenge may be to find an IMSB tool kit at a reasonable price that ships to Malta?
http://www.ebay.com/itm/Intermediate-Shaft-Seal-IMS-Retrofit-Pro-Tool-Kit-for-Boxster-986-996-997-99-/131377522345?hash=item1e96b5e6a9:g:h-wAAOSw0vBUi2es
