Thread: ecu swap
Old 10-30-2015, 08:32 AM   #10
thstone
Originally Posted by boxster View Post
Really? Wow thats what I want to hear. I found a second hand ecu together with immobiliser and key fob. Would I need to change those three for the car to work well? I will just need it temporarily till I do the test.
Yes, the ECU/immob/fob are programmed as a matched set, so you will have to swap all three for the car to run. This should let you pass the emissions test and then you can swap back to the modified ECU/immob/fob set. Just keep the second (stock) set for emissions testing.
I know this works because this is exactly what I do.
