Old 10-28-2015, 02:34 PM   #1
Ken Morgan
Clucking (Track Arms, Read)
Just replaced the rear track arms PN 986.331.043.07, TRW Parts from Pelican. It fixed the clunking noise coming from the rear. Parts fit perfectly, with no adjustments required. The old arms look perfectly good, except for the rubber bushing being very soft, almost mushy. I believe the new arm has a firmer rubber bushing compared to original. Cost was about $305 parts, $180 labor. The alignment was not compromised; however, should be checked after install. This is expensive fix just to eliminate the clunking noise, as otherwise did not make a difference in handling.
Ken Morgan
"03" Std Boxster, Seal Gray
Gray Interior, Black Top, 103K miles
30k on new dealer installed
engine due to IMS Bearing bolt
failure.
Ken Morgan is offline   Reply With Quote
