Old 10-07-2015, 03:01 PM   #2
Sassmatt72
looks good, top of bellhousing about 1" below/ from sheetmetal above.
check at tx mounts from below and make sure they look centered, circle inside circle.
center front mount in slots, to maximize adjustment in the future...
i was going to make a new sleeve to accept the OEM rubber front mount (circular tube) and ditch the alum mounting plate, (watch out it is not actually symmetrical, if mounted right and not cracked (in the rubber))..
good luck, my subie swap is driving (just).
Sassmatt72 is offline   Reply With Quote
