Boot kits are available for the outside joint but the outer joint are not replaceable (they can be re-greased). You can buy inner caps, boots, bearing and clamps. In the end they are not hard to rebuild, it's harder removing them than replacing the boots and bearing. There is about $160 to $200 each in cost. You will need a clamp crimp pliers, but can use a side cutter pliers in a pinch (not recommended because they don't pull the band evenly).
