Originally Posted by jcslocum
Take the door card off. On the back there are screws holding the 2 posts that the cover is hinged onto. You then have the cover loose in hand. Cover with whatever leather or vinyl you want. We had some black around so we used that as the cover was originally black. We also did the covers just above the inside door handle. Looks great!
Pedro's Boxster site has info and instructions too.
I read that you do not need to remove the door panel. You can remove the hinge pins between the cover and the door.
