Old 09-23-2015, 12:09 PM   #3
jb92563
jb92563's Avatar
Since my P0430 code comes and goes, borderline, I thought that fresh sensors may be just enough to pass the smog.
I realize what you are saying is true but I need a slight nudge to pass the smog and since this has occured AFTER a major smoke fest with the AOS going out I feel that carbon from all that oil is what may be hampering/plugging my cat and sensors.
I'll check the sensor Voltage curves and see if I can confirm what is happening.
In theory the Cats should last forever if they don't get plugged, fouled or broken ceramic matrix.
I take it the upstream O2 sensor voltage would be the nearly constant voltage and the downstream following the sine wave?
